RDM not opening or connecting to RDP sessions.
Hi, I have an ongoing issue with Devolutions RDM not opening up a new RDP connection or starting and failing with a blank, white screen. The only way to get these connections to open is by closing the entire RDM application and re-opening it. This seems to correct the problem for a while, but after a period of inactivity the problem resurfaces. Constantly having to close and reopen RDM is troubling.
All Comments (11)
Thank you for contacting us on that matter.
Could you please provide us with the RDM version and the data source you are currently using?
Do you see relevant error messages in Help - Application logs when experiencing this issue?
Would it be possible for you to create a portable installation of the RDM version and see if this issue still occurs? To do so, you will need to follow the instructions on this page.
https://docs.devolutions.net/rdm/kb/how-to-articles/portable-rdm-installation/
Érica Poirier
Hi Érica,
I'm facing the same issues as brentmoorhouse does. It happens occasionally during the day. After 1 RDP session fails with the blank screen, all following RDP sessions look the same – even the existing ones if they aer reconnected. This issue exists for me for the last 2-3 versions. I am currently on Version 2025.3.10.2 on macOS 26.3 (25D125) on a MacBook Pro M1 attached to a thunderbolt dockingstation. Attached to this are three MSI MAG301CR2 Displays with a resolution 2560x1080@120Hz and synaptics’s displaylink software.
Only quitting and restarting the app solves the issue.
Best regards
Andreas
Hi Érica,
Best regards
Andreas
@andreasmetzinger
I figured out that I have to quit fullscreen mode for this application. The screen reappears instantly. Then I can set this app to fullscreen mode again without any issues...
Hello Andreas,
Thank you for your feedback.
That's good news that you found a workaround to solve this problem.
Let us know if you still have an issue with the blank screen. We may want you to send us session logs and other information for the entry configuration.
Érica Poirier
Hi Érica,
sadly this issue doesn't resolve always by exiting fullscreen mode. In fact this solves the issue only 2 out of 10 times.
Is there any log i can send you for further investigation?
Kind regards
Andy
Thank you for your response.
Could you please confirm whether the issue still occurs on the latest version of RDM?
If the issue persists, please send the application logs available under the Help tab.
Tommy Sanders
Hi Tommy!
The error has occurred again in the past few days. The installed version is 2026.1.10.3.
Here is the log:
System.TimeoutException: Timed out connecting to pipe '/tmp/rdm-now-agent-dvc-12da3c46-664b-4063-b2ff-ae37aafb91bb'.
at Devolutions.RemoteDesktopManager.Business.NowAgent.NowProtoPipeTransport.Connect(String pipeName, Nullable`1 timeout, CancellationToken cancellationToken)
at Devolutions.RemoteDesktopManager.Business.NowAgent.NowAgent.Connect(Guid sessionId, CancellationToken cancellationToken)
at Devolutions.RemoteDesktopManager.EmbeddedFreeRDPAPIViewController.<>c__DisplayClass65_0.<<DidConnect>b__0>d.MoveNext()
Best redards
Andy
Hello Andy,
Could you try the latest RDM Mac version 2026.1.11.4 to see if that helps?
In the meantime, I'm moving this thread to the RDM Mac - Support forum section.
Érica Poirier
Hi Érica,
sadly this error occurred again today. My version is 2026.1.11.4 (macOS version 26.4.1 (25E253))
Log:
System.TimeoutException: Timed out connecting to pipe '/tmp/rdm-now-agent-dvc-454a2abb-7e2b-47e0-9ff0-5cb9060b542a'.
Kind regards
Andy
@Erica Poirier
Hi Erica,
I no longer use the installed version (.msi file) of Devolutions RDM because the issue wasn't getting resolved in subsequent newer versions. I have been using the portable version or zip file version (.exe file) of the product for a number of versions now. Using this version, I encounter the problem far less. I am currently on version 2026.1.18.0.
@andreasmetzinger I'll ask the development team to look into your issue.
@brentmoorhouse I have opened a case on your behalf, and someone from our support will contact you to get more information on the issue. As you are using the RDM Windows version, please post the issue in the RDM Windows forum section next time.
Érica Poirier
Closed
