I am following the Academy guide to create a script for restarting the Zabbix service. However, I ran into a problem right at the beginning.
According to the tutorial video, I should have an option called "PowerShell Script (remote)", but this option is not available in my environment. The only option I have is "PowerShell Script".
When I use it, all of my saved scripts are executed locally instead of on the remote machine.
Could you please let me know what I am missing or what needs to be configured?
Thank you for contacting us regarding this matter.
Could you please let us know your RDM version, as well as the workspace/data source you are using?
In the meantime, could you please try selecting the All tab instead of Macro/Script/Tool and let us know if that resolves the issue?
Tommy Sanders
