ALT+Tab to switch between tabs not working
Hi
I can't get ALT+TAB to switch between RDM tabs. I found the post https://forum.devolutions.net/topics/4928/keyboard-shortcut-to-switch-between-tabs which suggest this should just work out of the box. I have redirection of keyboard shortcuts disabled on the connections and the "magnet" at the bottom right is enabled. ALT+TAB currently just switches between apps on my local computer but RDM is only listed as one app (instead of each tab). Active keyboard layout is Swiss German.
Am I missing some setting?
Thanks in advance (really like the product)
All Comments (7)
Which RDM version and data source are you using?
Min
local sqlite and RDM 2024.2.21.0 64-bit
Thank you for your response.
Could you please update your RDM to the latest version (2024.3.10.0)?
Let me know if this resolves the issue. If not, I will proceed with opening a case for further investigation.
Tommy Sanders
Hello
I updated to 2024.3.10.0 but the behavior is still the same.
Should it work? Does it work for you?
Thanks
If I understand correctly, you would like to switch between tabs using a keyboard shortcut in Remote Desktop Manager.
Please try using CTRL + SHIFT + RIGHT or CTRL + SHIFT + LEFT to switch between tabs.
Let me know if this helps.
Tommy Sanders
Hello
So does ALT+TAB not work to switch tabs? Like it does on Microsoft Edge where each tab has its own entry?
Its not just inside RDM, I want to be able to switch from a specific remote session to, say a browser window and back to another specific remote session.
Thanks
That’s correct! To switch tabs, you need to use CTRL + SHIFT + RIGHT/LEFT.
When you mention a browser window, are you referring to a browser outside of RDM and then returning to a specific remote session within RDM, or is everything happening inside RDM?
Tommy Sanders
Closed
