Problem with Winbox
ln last ver 9.0.6.0 is problem with start Winbox(Mikrotik). RDM make mistake with insert username and password to Winbox.
Password from RDM insert to loginname in Winbox and password in Winbox stay empty.
All Comments (4)
Could you post the new Winbox command line parameters here?
I mean problem is in new RDM 9.0.6.0. Winbox is the same over 2 years. I return back to RDM 9.0.5.0 and all is working correctly.
We haven't changed anything in Winbox. I will double check
A new version of the add-on is now available and should solve your issue.
http://remotedesktopmanager.com/Home/AddOn#winboxformikrotik
André Sanscartier
