SQL Offline mode
I want to use SQL offline mode when I am not on the network but instead I get this error:
NullReferenceException - Object reference not set to an instance of an object.
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.LoadConnections(BaseConnectionDataSource connectionDataSource)
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.RefreshConnections()
at Devolutions.RemoteDesktopManager.Forms.FrmMainBase.RefreshAllConnectionView(Boolean saveState, Boolean checkOnline)
at Devolutions.RemoteDesktopManager.Forms.FrmMainDockable.tmFirstLoad_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Is it a bug or am I doing something wrong?
Sjoerd
Cheers!
Sjoerd
I will verify, I'm sure that it's a bug with the new security I'm currently implementing.
edited by dhervieux on 10/8/2010
I just uploaded a new version of the binaries:
http://remotedesktopmanager.com/download/Setup.RemoteDesktopManager.5.8.3.5.exe
Thanks David. Problem fixed!
Cheers!
Sjoerd
