I would like to include my VPN access as a connection in RDM.
we currently use the following connection setup:
When we run it from our desktops, we do this:
We then receive a token in an email, and the screen above gets a box where to enter the token sent.
This works very well for us.
I have tried to set up a similar confguration in RDM which looks like this:
when i save and submit the request, it spins for 15 seconds and then drops - what am i missing?
Thank you for reaching out to us regarding this matter.
Could you please try changing the connection mode to SSL VPN (deprecated)?
This option is still available for the time being, but unfortunately, it is scheduled to be removed in a future version.
Please give this a try and let me know if it resolves the issue. If it does, we can explore a suitable workaround to ensure
continued functionality once this option is no longer available.
Tommy Sanders
@cvelaI suggest trying the SSL VPN (deprecated) connection mode in RDM, as recommended by the support team. Also, make sure the email-based OTP authentication is properly supported. If this works, consider finding an alternative before the deprecated mode is removed in a future release.
Geometry Dash Full when i save and submit the request, it spins for 15 seconds and then drops - what am i missing?
@cvelaThe explanation is clear and helpful, especially the suggestion to try the SSL VPN connection mode. Great support and useful information for anyone troubleshooting FortiClient integration with Remote Desktop Manager!
