Window is slightly too small to fit the RDP session
A fix for this issue has been implemented in version 2026.3.17.0
Implemented
I just upgraded from 2.x to 3.a6 and now every windows server I remote into has scrollbars on the bottom and right side. I never had this problem with the 2.x version. I found that if I check the Smart Sizing option it resizes and looks OK, but do I need to do that for all 2000+ of my sessions?
What changed that I didn't have to do this with 2.x but have to do it with 3.x?
Thanks
All Comments (7)
Yes. New version start RDP with smartfit with scrollbars. Very ugly
Thanks we have logged a ticket and we will investigate a fix.
Paul Dumais
I guess this is the same thing. DIdn't see this until now.
https://forum.devolutions.net/topics/56781/all-rdp-sessions-open-with-scroll-bars
@kelemvor
Yes, this is the same thing.
You can follow the thread on the forum for updates: https://forum.devolutions.net/topics/56781/all-rdp-sessions-open-with-scroll-bars
@pavlyukoff Can you further explain the "smartfit"? Are you talking about the workaround with smart sizing or something else?
You can also follow the forum thread for updates.
Alexis Beauparlant
@Alexis Beauparlant - yes, i'm about it and yes. As for me - helps turn on scaling (not smart sizing) and then turn off it (every time).
Already moved to watch progress to those topic. Thanks
@pavlyukoff
I see, thank you for clarifying that!
Alexis Beauparlant
Thank you for your patience while our team looked into the issue you reported.
I'm happy to let you know that the latest version of Remote Desktop Manager (2026.3.17.0) includes a fix for this problem. You can download it from our website here:
https://devolutions.net/remote-desktop-manager/download/
Once you have installed the update, could you please test it in your environment and confirm that everything now works as expected? If the issue persists or if you notice anything unusual related to the same original problem, just reply to this message with a few details, and we will be glad to look into it further.
Maxim Robert
