I turned on verbose logging, and am seeing this whenever a connection is refused:
Thank you for contacting us on that matter,
Could you please update your RDM to the latest version and let me know if the error still occurs? (2026.3.16.0)
Tommy Sanders
Unfortunately, updating is not an option. "Please update" is a rather lame response, especially when a detailed log is provided. The last time I attempted to update to the newest version, almost all of my connections failed and I had to back out the update. It should be a trivial matter to analyze the difference between how RDM and Putty interact, and resolve it. I have created an entry that uses all the different keys, every possible setting, and it still fails. Did you look at the logs I sent?
Enable the "Skip environment variable setup" in the "Advanced tab". It should resolve the problem which is frequent with Cisco devices.
Denis Vincent
That worked! Thank you!
