alt+tab - After alt-tabbing to RDM... I have to click alt to allow me to use session... ALT seems to get stuck
Since the last update, when I alt+tab to RDM... its like the ALT becomes stuck on..
Its never done this before... So I can only think its related to new update...
Anyone else seeing this.. Its really annoying... especially if i forget and it then starts running menu commands in the remote session as its an ALT+<Key> combo..
I saw there was a similar issue a couple of years ago
Also seeing this behavior. I'm finding all sorts of keyboard shortcuts on my remote servers I didn't know existed today.
Yeah, i have nearly corrupted a bunch of stuff..
this is a real problem... Its a problem on two different machines that I use.. so i don't think this is specific to a local install...
In addition I have never seen this before... So pretty sure it got introduced in an update... :)
Won't be long before something gets potatoed and its not noticed until too late...
I have had it collapse lines in editors, then all of a sudden I was comparing two files... :)
Good Times...
Hello Allan,
Thank you for the report.
So we can try to reproduce this on 2026.3.15, could you please share the following:
The workspace type you use
The session type where it happens (RDP, SSH or other), and whether the session is in a tab, undocked, or opened externally
The operating system of the remote machine
Thank you in advance!
I am running into the exact same issue now. Happening with RDP sessions, in a tab. Remote machine OS is normally Windows Server, multiple versions (just got it on Windows Server Datacenter 2022).
It really needs to be fixed ASAP.
Hello Allan and Spencer,
Thank you for the additional details.
We reproduced this in-house. In an embedded RDP session, after using Alt+Tab to come back to Remote Desktop Manager, the session behaves as if Alt is still held down. Our developer team is working on a fix.
Until then, this workaround prevented the issue in our tests:
In Remote Desktop Manager, go to File > Settings > Entry types > Sessions > Remote Desktop (RDP), then open the Advanced tab.
Set Enable API hooking to Disabled, then restart Remote Desktop Manager.
This setting applies to all RDP entries. If you connect to any RDP entries through Devolutions Gateway, do not apply it.
The issue is set to be patched in our next minor version release of RDM.
We will update you once it's available.
Thank you again!
Thank you for your patience while our team looked into the issue you reported.
I'm happy to let you know that the latest version of Remote Desktop Manager (2026.3.17.0) includes a fix for this problem. You can download it from our website here:
https://devolutions.net/remote-desktop-manager/download/
Once you have installed the update, could you please test it in your environment and confirm that everything now works as expected? If the issue persists or if you notice anything unusual related to the same original problem, just reply to this message with a few details, and we will be glad to look into it further.
Maxim Robert
sweet, thanks... this was a right pain...
Thank you for your feedback. We're pleased to hear that everything is now working as expected.
Please don't hesitate to create a new thread if you need any further assistance.
