Since few last versions (at least 3) of RDM for Windows, I am observing problems with keyboard after Alt+Tab:
open SSH session
write something - all ok
Alt+Tab to other Windows window
Alt+Tab back to RDM and SSH session
type something - some shifting key is down, so the entered keys are garbled - that's the problem
press Windows key twice (open and close Start menu)
type something - everything is fine
I have Windows 10 on Dell laptop.
RDM is from zip file, sessions file taken from few versions back.
Already disabled all keyboard shortcuts but it does not help.
Where to look for the problem?
Hello PB,
Thank you for contacting us on that matter.
Could you tell me if this is what you get when switching?
^[b^[a^[s^[d^[;^[l^[f^[k^[b^[h^[n
Patrick Ouimet
I wasn't exactly checking the bad characters but seems like they are similar as yours.
But sometimes keyboard produce different results after Alt+Tab switching, I am mostly using Midnight Commander, so then I can't go thru files and folders with arrow keys.
The worst working keys then are not arrows or enter, but many other characters - letters or combination of shifting keys and a letter.
Any updates since the latest update from 26th September? In my case the issue still exists.
Thank you for your response.
A case has been opened with the development department to investigate this issue. Once a solution has been found, I will post the updated version here.
Patrick Ouimet
This is extremely annoying. Need it fixed ASAP.
I have the same issue when switching alt+tab or change windows focus.
As I said by PB, is extremely annoying.
After "sudo su -" I alt+tab and then cannot write.
Thank you for those feedback,
I've sent them to the developer who is in charge of this issue.
I'll keep you posted,
Patrick Ouimet
Greetings,
I am pleased to inform you that the problem you reported has been resolved in version 2023.2.33.0. This updated version will be released soon.
I recommend that you monitor the release of this version and once it's available, update your RDM and attempt to replicate the issue again.
Kind regards,
Patrick Ouimet
Greetings,
Kind regards,
Thank you so much!
I was going crazy. Nice to find this is already found and resolved. Hoping it is out soon.
Greetings,
Kind regards,
Hi Patrick,
When will the new version be released? Still waiting :_(
Thank you.
Hello Fburria,
Unfortunately, I do not have this information. However, the release should be coming soon.
Patrick Ouimet
New version has came out, but still sometimes the problem still exist.
Oh, this are very bad news :(
On the other hand, at the moment, don't had the issue, hope it don't pop again.
I can also confirm that at the moment with 2023.2.33.0 I can't reproduce the issue.
Thanks Dev-Team!
Could you be more specific with the expression sometimes?
Does this issue still occur once in a while every hour?
After how many Alt-Tabs does this issue occur?
Patrick Ouimet
Hi Patrick,
Was your question for me?
If yes, it depends .. Example: RDM vs. OneNote
Writing in Shell > Alt+Tab > OneNote > Code Snipped > Alt+Tab > Shell: writing or removing > special chars
Alt+Tab to OneNote > Closing OneNote > Alt+Tab back | this solved sometimes the issue for the ssh sessionBut this happens also with Notepad++ and VSC and sometimes
Best Regards,
Tobias
I observed that twice with new version, once garbled characters yesterday, today second time SSH server was getting garbled characters, but other SSH session was ok, however I wasn't able to reset the input to enter proper commands.
Hello PB,
Thank you for this feedback.
As Tobias mentioned, could you tell me if this issue occurs with Notepad++?
Patrick Ouimet
Seems like not, I am using Notepad++ but didn't the problem occured with it.
To address the keyboard issue in RDM for Windows after Alt+Tab, consider updating RDM to the latest version, checking keyboard language settings, reviewing shortcuts, verifying drivers, and examining session configurations.
If this issue still occurs with the latest version.
Could you tell me if you are interested in doing a remote session to investigate this further?
Patrick Ouimet
Seems like with 2023.3.22.0 x64 problem does not exist, but not tested it much.
About remote session we have talked that for my company's computer this is impossible.
