show navigation panel when application startup not work
A fix for this issue has been implemented in version 2026.3.15.0
Hi
The function show navigation panel and focus navigation panel after application startup when I setup navigation auto hide not working any more in new version. Can you check on this.
All Comments (9)
Hello
Any one can check on this?
Just check any update on this.
Sorry for the late reply.
My team is currently looking at this issue. We should be able to get back to you this week regarding this.
Thank you for contacting us regarding this matter.
If I understand correctly, you would like the navigation pane to open automatically when you launch RDM. Is that correct?
If not, could you please provide additional details about the issue you are experiencing?
Also, could you please confirm which version of RDM you are currently using?
Tommy Sanders
Hi, Tommy
Yes, it has this function before. But seems we lost this in new version.
Thank you for your response.
I have reported this issue as a bug and will get back to you as soon as I receive an update from the development team.
Tommy Sanders
This is a known issue, and the fix will be included in version 2026.3.14.0, which is scheduled to be released in the next few days.
Tommy Sanders
If possible, could you update your RDM to the latest version (2026.3.15.0) and see if the problem persists? This version should resolve your issue.
Latest Version: Download RDM
If the problem persists after the update, please let us know so we can inform our development team.
Maxim Robert
Hi
This worked, thanks.
