RDP coonections are by default opened in very low resolution - v2026.3.5
A fix for this issue has been implemented in version 2026.3.8.0
Implemented
when opening connection from workspace with updated database schema, the connection resolution is very tiny:
using Reconnect on opened connection restores normal resolution, but when opening connection again, the same tiny resolution is used
All Comments (6)
the RDP session settings state, that Remote desktop size is Automatic. How can I set it so, that (embedded) RDP session fills current window size, whatever it is?
When using Open (embedded/tabbed), the RDP session fills the window size.
