I receive 4 warnings for a single entry.
A fix for this issue has been implemented in version 2026.2.17.0
Implemented
I have one entry that is linked three times.
Since the entry is about to expire, I receive four separate warnings for it.
Is this an error or ok ?
Thank you for reaching out about this matter.
I was able to reproduce this behavior on the latest version. After discussing it with our development team, they confirmed that this is not the intended behavior and understand that it may cause friction.
I will log this as a bug on my end, and the development team will work on implementing a fix.
I'll keep you updated as soon as a version containing the fix has been deployed.
Jacob Lafrenière
We have fixed an issue where entries with multiple shortcuts generated duplicate expiration notifications on the Dashboard and Action Center — RDM now shows a single notification per entry. It will be available starting from version 2026.2.17.0 of RDM.
I'm pleased to inform you that a new version of RDM (2026.2.17.0) has been released, featuring the fix for your issue.
Latest Version: Download RDM
Maxim Robert
