SFTP lower pane refresh keep current folder
This feature has been implemented in version 2026.2.14.0
1 vote
It is just something small, but in the SFTP view, where you have an upper pane showing the target folder structure and a lower pane with the local systems folder structure, if you refresh the upper pane, it keeps the folder that was currently opened, but the lower pane will close everything and open the first default one.
Would be nice if it could remember the current view like the upper pane does.
All Comments (6)
We will open a ticket to investigate this and see if it can be improved. We will keep you updated on any progress.
Best Regards,
Michaël Beaudin
Would it be possible for you to send us a video of the issue? It will help us find the cause more easily. I'll send you a secure link in private, and you can share the video with us that way.
@Olivier Savoie
Sure, done :)
We've fixed the local (lower) pane so that refreshing now preserves your currently opened folder.
This fix will be available starting with version 2026.2.14.0.
Please don't hesitate to reach out if you have any questions or notice anything else.
@Olivier Savoie
Great, thank you very much!
I'm pleased to inform you that a new version of RDM (2026.2.14.0) has been released, featuring the fix for your issue.
Latest Version: Download RDM
Maxim Robert
