RDM version 2026.2.8.0 64-bit (PreJIT).
Using the right-click button to paste a few lines into SSH terminal,
the dialog does not respect Windows UI rules:
"Yes" button must come first (on left), then "No" button (on right) - See picture below, it's reversed, and this is very annoying as this is the opposite of all other dialogs in the system, this will cause error as we're used to the other way in Windows.
ESC key must invoque the "Abort" modal result (aka "No" in this dialog). Clicking on the "x" button to simply abort is annoying.
I will open a ticket so we can improve this window, thank you for reporting this.
Thanks for bringing this to our attention. We've gone ahead and done several improvements to this window. You can expect this to reach live with the upcoming 2026.2.10 version.
Jafran Majeau
I'm pleased to inform you that a new version of RDM (2026.2.11.0) has been released, featuring the fix for your issue.
Latest Version: Download RDM
Maxim Robert
