Issue with Favorites display since 2026.2.5.0 64-bit (PreJIT)
A fix for this issue has been implemented in version 2026.2.8.0
Implemented Backlog
The custom colours configured on the entries under User Interface - Tab colour and Entry colour are no longer showing on any of the entries in favorites, also there are little white stars on the folders in favorites that I am not sure where there before, but they could have been
All Comments (7)
I'm also able to reproduce this issue. I will open a ticket so we can address this.
We've fixed the color issue in the Favorites section. This should take effect with the upcoming 2026.2.8
Jafran Majeau
@Jafran Majeau
Just installed the latest version released today and it has not fixed the issue.
If I'm not mistaken, that version should not be 2026.2.8. Considering the timing it is very likely that my fixes did not reach the version you've just installed.
Jafran Majeau
@Jafran Majeau
Yes, you are correct the latest version is 2026.2.7.0 64-bit (PreJIT), so I will wait for the next version and check once that is released.
I'm pleased to inform you that a new version of RDM (2026.2.8.0) has been released, featuring the fix for your issue.
Latest Version: Download RDM
Maxim Robert
