Hotkey to Launch RDP from Vault in External Window
Is it possible to create a hotkey to launch a selected Remote Desktop connection from my vault directly in an external window? Any built-in options or workarounds would be appreciated.
Thanks!
All Comments (1)
Thank you for contacting us regarding this matter.
The only way to achieve this is by using SHIFT + ENTER, and you need to ensure that your entry is selected. If the entry is not selected, this will not be possible. In that case, I will transfer your post to the feature request section.
Please let me know if you have any questions.
Tommy Sanders
Closed
