Fullscreen mode is not truly fullscreen in 2025.3.9.2 (visible borders)
Resolved
In the latest version 2025.3.9.2, fullscreen mode no longer occupies the entire screen. There are visible margins left around the window (approximately ~10 pixels on the left and right sides, and ~5 pixels on the top and bottom). This was not present in earlier versions and breaks the expected fullscreen behavior, especially noticeable on macOS with multiple displays.
Thank you for reaching out to us regarding this issue.
Could you please confirm whether the behavior occurs on the main RDM screen or when opening an entry?
  • If it happens when opening an entry, please go to the Properties and check whether the Display Settings are set to Smart Sizing.
  • If it appears on the RDM main screen, kindly send us a screenshot of what you’re seeing.
Looking forward to your response.
Tommy Sanders
I had version 2, I'm attaching a picture of it.
But now I've updated it to the latest version, it doesn't produce the error.
Gábor
Thank you for your response,
I'm glad to hear that the update solved your issue.
Please do not hesitate to contact us for further questions.
Tommy Sanders
Closed
