Drag and drop reordering of connections (navigation menu)
1 vote
I have learned that one needs to enter the properties of each connection and place a number that will set the connection's ordering in the navigation menu. This is easy if there are 10 or less but gets progressively harder to manage as the number of connection involved increases. Royal TS has this implemented so I don't think it can be difficult. Please see what can be done as my navigation is extremely scattered and disorganized as I don't have the time to mess around with each connection's properties. Additionally I'm always adding connections and every time I do that I have to reorder all the connections.
This would be very much appreciated.
All Comments (2)
Thank you for reaching out to Devolutions Support.
I’ve forwarded your feature request to the Remote Desktop Manager team for better follow-up and consideration by the development team.
Carl Marien
I've moved your thread to the feature request forum. We've also had a similar request here: https://forum.devolutions.net/topics/45001/proper-sort-in-tree-view
We have noted your interest in such a feature. Adding support for this may require having two different sorting modes, one which is the current one, and one letting you drag-drop to reorder. We will have to see what the best way to approach this is.
Ends in 4 days
