1 vote
Hello tech team,
just installed RDM 2025.3.20.0 on WIndows 11 25H2, build 26200.6899.
Using an SSH session, I open the SFTP panel, and I can't drag & drop to or from Windows Explorer.
1/ From Windows Explorer to SFTP : In the attached screenshot, see the cursor when hovering SFTP directories, when dropping in my own /home, nothing happens.
2/ From SFTP to Windows Explorer : the cursor don't even change, meaning the drag didn't start.
Here is a screenshot when dragging from Windows Explorer to SFTP.
This is not currently possible but I checked with the developer who reworked the file explorers, and it should be possible to improve this behavior. I moved your thread to the feature request forum and opened an internal ticket.
The drag/drop capabilities between RDM's file explorers and Windows explorer will be added in version 2026.3.4.0.
Jonathan Del Signore
