RDP on MacBook Pro (Silicon) using over 3GB of memory.
A fix for this issue has been implemented in version 2026.3.0.5
New macbook pro m4 pro and having only one RDP connection opened, but for 3days, RDM is using 3.5GB of ram. Connection is opened to a LAN PC, and not even focused on the tab (using it for OTP codes mostly).
Closing the RDP session does not free up the ram.
(also, a bunch of about: processes that exits if application is closed)
Screenshot 2025-10-29 at 03.59.03.pngScreenshot 2025-10-29 at 03.57.55.pngScreenshot 2025-10-29 at 03.57.14.png
Version: 2025.3.6.9
Thank you.
All Comments (31)
Thank you for reaching out to us regarding this matter.
Could you please confirm the type of RDP in use? For example, is it FreeRDP?
In the meantime, could you also check if there is any device or system currently enabled or associated with this entry?
Tommy Sanders
@Tommy Sanders
Hi, using it only in tabbed/embedded mode - If I was to using it detached, I have the Microsoft app for that so not sure who would use RDM to open sessions same as you do with the MS app :)
Thank you for your response.
I will run some tests tomorrow and will follow up with you shortly afterward.
Tommy Sanders
