Copy Paste in RDP web brower (rdp web client) does not work anymore
after patching dvls serveur to v2025.2, copy/paste from rdp windows session to localhost using any kind of browser does not work anymore.
Any known issue ?
Rgds
/Christian
Thank you for your feedback.
This issue has already been reported, and a ticket has been opened internally.
We will post it here once a fix is available.
Thank you for being so patient.
Érica Poirier
@Erica Poirier
Hallo,
It seems to be even worse with the web SSH client:
  • copy/does not work at all, even in the same shell, the text appear but it not interpreted
  • some time opening the session fails
  • some times disconnected and relogin mandatory
  • huge number ot http 400 unauthorized when login out after having tried a SSH connection
Rgds
The copy/paste option in RDP and SSH has been solved internally. This fix will be available in version 2025.3, which should be released in early October.
For the other issues you are experiencing with SSH entries, could you send us the Gateway logs for those problems?
Érica Poirier
