i'm trying to get vmware-vmrc.exe working.
If I connect against a ESX-Host it works perfectly, but when I try to connect against a vCenter i got the following error:
Connection failure: A new connection cannot be made for the remote virtual machine "[path] my/machine.vmx" on host "myHost" - The request refers to an unexpected or unknown type.
I did make some analysis and I found out, that the Esx-Hosts are accepting connection on Port 902 TCP. But my vCenter only accepts connection on Port 902 UDP.
Is there some configuration I might do to get this working? Or does anyone know about this issue?
thanks,
Ben
Could you please post a screen shot of your RDM session configuration.
edited by stefane on 6/27/2013
Stéfane Lavergne
Hello Stefane,
hier is the screen:
Maybe its a problem with the different versions.
The vmrc-Plugin 5.1 does generally not work (when starting, it says VMWare Player is not proberly installed). So i use the 5.0 plugin.
The ESX-Hosts are currently on 4.1 and 5.0. vCenter is on 5.1.
Connecting to ESX-Hosts with 4.1 and 5.0 running works fine, but connecting to vcenter 5.1 brings the error i descripted earlier.
The Plugin 5.0 tries to etablish a connection on TCP Port 902 but vCenter 5.1 is listening on UDP Port 902.
Hopefully there is a solution :)
Ben
If you try to connect manually (not using RDM) does it work?
FYI
The command line options have changed in v5.1 of vmrc-Plugin. See this topic (not yet fixed)
http://forum.devolutions.net/topic2542-vmware-remote-console-not-working-with-.aspx
Stéfane Lavergne
If I connect manually its the same. Against a ESX-Host with 4.1 or 5.0 works fine (actually I dont have a ESX-Host on 5.1).
Against vCenter 5.1 same error.
The Link you postet is exactly what i said in my first post. But this thread was postet 5 month ago and there is no solution or workaround.
... and it seems that there were more changes on 5.1 than the command line options...
Even when starting v5.1 with no parameters it will fail.
Does vmware-vmrc.exe work in your lab on 5.1? I can't find any post about that.
Ben
In our environment launching from the vSphere Client it connects. Command line looks like this:
vmware-vmrc.exe --parent-PID 123456 --instance-ID "vmrc-ax-p-{12341234-1234-1234-1234-123412341234}" --modes 2 --message-mode 2 --features 4
The command line has changed; we will need to figure out what parameters work with the v5.1.
Sorry for the inconvenience,
Stéfane Lavergne
Has this been fixed in the latest version of Remote Desktop manager?
edited by Innsanctum on 11/15/2013
doesn't look like..
