Collapse via CTRL - and CTRL + doesnt work from folder navigation pane
Backlog
1 vote
Hi, as state above this doesnt always work. When I select a server from the server folder in our group vault and want to collapse all the other servers this does only work when right click and choose collapse all. In the navigation pane CTRL - and CTRL + doesnt work. From initial navigation pane is does work. Just from a folder below it doesnt. Is this a bug?
Thank you for contacting us regarding this matter.
This is expected behavior. I will transfer your post to our feature request list.
Tommy Sanders
We'll monitor this thread for additional feedback to help us prioritise this request. As a note, we would need to add an "expand" and "collapse" for the selection, rather than "expand all" and "collapse all" which currently apply to the whole tree.
Thanks Hubert or when CTRL -/+ is pressed its aware where currently the focus is.
