Macros/Scripts/Tools working on users in shared vault, not in private vault
Implemented
I've written a powershell script to help reset passwords from the RDM vault.
we can right-click a username/password entry then select the macro and it will read the old password, generate a new one... then if accepted, change the password in AD.
This used to work in earlier versions , both in the shared vault and in the private vault, don't know in which version it ceased to stop, but not working in 2023.3.39.0 / 2024.1.x
If I right-click on a username/password entry in the shared vault:
however if I right-click on a username/password entry in my private vault I get:
so there is nothing below 'Who Is'
Regards, Ben van Zanten
All Comments (2)
Hello Ben,
We were able to reproduce this issue, we will open a ticket and investigate.
Hello Ben,
This should be fixed starting with our next version, RDM 2024.1.21.0, alongside a few other fixes relating to the visibility of the macros depending on the context.
Please let us know if you still encounter issues with this version once you're able to test.
