RDM Connection Error: "No match for kex algorithm
Resolved
Hello everyone,
I encountered an issue with my Remote Desktop Manager (RDM) after a recent crash caused by a hard reboot of my computer. Thanks to the assistance of @David Hervieux, I was able to recover my online database successfully. However, I now notice that some settings have reverted to their defaults.
Specifically, when attempting to connect to my Cisco switches, I encounter the following error message:
"No match for kex algorithm:
Client sent: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,ext-info-c,ext-info-c
Server sent: diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1"
I followed the instructions provided in the guide at the following link: [insert URL from original message]. However, the issue persists even after attempting the recommended configuration changes.
Could you please advise me on the next steps I should take to resolve this connection error?
Thank you in advance for your assistance.
Aviad
bb4df66c-5766-47de-bec7-84d1eb1e2eeb
5efb7fe6-72f0-4a4b-ba15-d29826ff2c96
All Comments (5)
Hello Aviad,
did you tried the steps from the SSH Algorithm Support KB article?
Min
Thanks for your reply
i followed the guide but i still gets this error
Hello Aviad,
Min
You're receive exactly the same error message?
Did you enable also this two options on the 3rd tab?
Min
Great! - , i have enable this two options on the 3rd tab and now it works!!
Thanks a lot
ebf0d2ac-aaca-430e-8ad3-2d628aca1112
Min
Awesome! Thanks for your feedback! 😉
Min
