RDM embedded Edge behavior - FortiNet SSL-VPN Portal
We have noticed that embedded Edge does not open connections on webportal FortiNet SSL-VPN portal 6.0.0.
If Chrome is used or external Edge portal works as it should?
In chrome we have issues with typing macro described here https://forum.devolutions.net/topics/38256/typing-macro-issue
DVLS: 2022.3.4
RDM: 2022.3.18
Rok
Have you tried the suggestion for Chrome? Increase the wait time
Yes, we did as suggest in https://forum.devolutions.net/topics/38256/typing-macro-issue but it does not help. I guess I was not clear with description - typing macro takes the last digit and types it few time (I think 6 times as much as whole OTP would have digits)
We've been able to replicate this issue with typing macros trying to send information in Web Browsers, and we have applied a fix for it. The fix should be available next version (2022.3.24)
Jafran Majeau
