Typing macro issue
we are using typing macro on some websites that has login in combination with OTP.
It works OK on verison RDM 2020.3.29 but we have a problem on RDM 2022.2.21 where the typing macro takes only last digit. It works f we use IE as a browser.
Rok
All Comments (4)
Would it be possible for you to increase the value of your "Initial Wait" to 10 seconds and see if the same issue occurs? Since only the last digits are being typed, I suspect that on the new version, it might take a little bit longer for the web page to fully load, causing your typing macro to be incomplete.
James Lafleur
We tried that, doesnt make any diference in behavior and sorry, I guess I was not clear with description:
Typing macro takes the last digit and types it few time (I think 6 times as many times as whole OTP would have digits) so I would guess it is not connected to macro started typing to soon...
Rok
Thank you for your swift reply!
On RDM 2022.3.21.0 would it be possible for you to create a new "Website" entry and see if the same issue occurs? From what I can gather from your screenshot, it seems that you are using what we now refer to as a "Website (Legacy)" entry.
James Lafleur
We've been able to replicate this issue with typing macros trying to send information in Web Browsers, and we have applied a fix for it. The fix should be available next version (2022.3.24)
Jafran Majeau
