Converting mdb base to SQL
Hello !
Am trying to find a proces on how to convert my actual .mdb database to an SQL version.
I checked on this forum before and found some old tipsandtricks link, but it's a dead one now sadly...
Any guideline would be much apreciated.
Thanks
Cédric
Hello Cédric,
The only way would be to export your actual database in a .rdm format and then import it in a new SQL database you would have created in RDM.
You would also need to create the users and review all the administration settings (permissions) in the newly database.
Here is a topic to help you with the export/import: Data Migration
Christine Breault
OK, thank you Christine for the help. Will do some testing
Welcome Cédric
Christine Breault
