Hi
I would like to use only 2 of my 3 screens (Same resolution) for 1 RDP connection.
But I can't seam to get it to work.
The connection is imported from a RDP, not sure if this can "corrupt" things, but I need NLA disabled, and I couldn't find a way to do it in the settings.
But I have set the following to both 1 3 (Windows Setting ID number) and 2 3 (Devolutions Window ID) but when ever I have 2 number it still only connects on 1.
If I select All in the dropdown, then it uses all 3 without problem.
Regards Lars
Remote Desktop Manager connected with Devolutions Server running newest versions.
------------------------Signature------------------------
Sorry if any of above sounds harsh or provoking, it is NOT meant as such, but I have Asperger's and don't always know.
My intentions is always to be friendly.
Could you try entering it using the following format: 2,3 (a comma between the monitor numbers)
Actually, could you make sure to check "span on multiple screens if possible"? I might be wrong on needing a comma, I think spaces are supported. We have a knowledgebase article that mentions this scenario: https://kb.devolutions.net/rdm_microsoft_rdp_display_issues.html
Hi
Thank you for you answer, but I have tried both , . ; and space.
I have tried SPAN - But it overrules and spans the screen to all 3 screens.
I have now tried to make a copy of my RDP file, remove all lines except for the hostname, the two needed for connection and the redirection of drives. But it gives the same, so I do not believe that this is due to the RDP file being imported.
I'm wondering if it could be something with the 3 line in the screenshot I posted "Display".
Is External, Default, Current Desktop the correct setting?
Regards Lars
Hi Lars,
Would you be willing in testing this setup and see if it resolves your issue. Since you wish to display from screen 2, change the display setting of your entry from Current desktop to Desktop #2.
Let us know if this works for you.
Christine Breault
