RDM - Remote session resolution is too low
Hi
Im a newb to RDM.
Noticed that the RDM sessions resolution is very low, hence the gui and text are very large.
However, one particular server's session, which is server 2008R2, the resolution seems fine. The others, which are non 2008R2, resolution is very low. I have tried all sorts of different screen sizing mode, and remote desktop size settings from the "Display" tab from properties, but the resolution will not change.
I am thinking it may have something to do with my custom scaling setting on my machine. It is set as 125.
However, i have successfully used Microsoft RDCM previously and had no resolution issues on remote machine sessions.
Any suggestions?
Thanks
Dave
All Comments (1)
Hi Dave,
Thank you for reaching out to the community.
You could try to disable the scaling on high DPI and see if this works best for you. You will find this option in File – Options – User Interface as mentioned here with other ways to achieve it.
Christine Breault
