'User Interface' section in entry properties tab order not correct
Resolved
When tabbing between elements in the User Interface section of an entry, the keyboard tab order seems to be incorrect.
I have been able to reproduce this issue in the "User Interface" section of an RDP entry. Have you observed this behavior in other types of entries as well?
I have opened a ticket with our Engineering Department to see what can be done on that matter.
I will be in touch as soon as I will have an update on this.
James Lafleur
This is the only place that I've noticed this so far. If I find more I will write a post for each one.
Thanks!
Bill
This issue has already been fixed (although quite recently). The changes should be part of the next available patch.
Jafran Majeau
