Edit -> Batch Edit -> Edit Entries -> General Settings: User Interface
This dialog box section is broken/confusing...
* The 'Tab Group' multi-edit drop-down box should be read-only ('Custom' or 'Inherited' values only - it lets you type in a value, which is confusing)
* The second multi-edit drop-down box has no label - it should actually be labeled 'Tab Group Name' or something similar
Thanks!
Bill
All Comments (2)
Hello.
Thanks for reporting this issue to us. The field should indeed be read-only, and we will also add a label for clarification.
Jafran Majeau
Sounds good, thanks!
Bill
