Copy Username and Password does not work in all browsers after 2019.2.14.0
Repo:
1. Create a credential with username and password
2. Open browser to portal.azure.com - it now sits at the login screen
3. In RDM use Copy Username and Password
4. Paste username into the portal.azure.com
5. Different things happens depending on browser - se below
Firefox:
Everything works at it should.
Username and password gets pasted in as expected.
Edge Chromium (Dev and Beta channel):
When pasting in the username, the password is inserted instead.
Can't paste anything in after this.
Google Chrome (normal channel):
Edge:
When pasting in the username, nothing happens.
IE11:
Notepad (just to test it):
This problem started after updating RDM to 2019.2.14.0
Problem still happens in 2019.2.15.0
Everything has been tested on Windows 10 non-insider and insider slow ring.
Do you encounter the same issue reported here?
https://forum.devolutions.net/topic32790-problem-with-copy-username-and-password.aspx
Hi!
Yes, looks like the same issue. Didn't think of checking out the support forum for duplicate posting :\:
Let's keep the issue going in that post, as it has the most information so far.
