Problem with Copy Username and Password
Implemented
Hello
Having a strange issue with Copy Username and Password
Clicking CUaP and Pasting into notepad works fine. Clicking CUaP and pasting into Chrome (or Edge 80.0.320.3, so it's likely to be a Chromium issue) just pastes the password. Seems to work properly in IE, although nothing happens in Edge 40. I've tried both Clipboard copy methods. Copy Username and Copy Password both work as expected.
Thanks
All Comments (46)
What version of RDM are you running? Is the clipboard history (Windows(keys)+V) enabled?
Stéfane Lavergne
Hi Stefane
I thought to myself "I must remember it include the version number", then clearly forgot!
It's version 2019.2.15.0 64-bit.
Clipboard history is turned off
Thanks
Thank you,
So, what most likely is happening, something is taking/stealing the content of the clipboard.
With CUnP we first put a promise of text (Username) into the clipboard, wait for some other app to request (paste) the text for which we then get called to supply. We then clear the clipboard and start over with the Password.
So my guess is some other app is asking for the Username, prior to your paste in Chrome/Edge...
Why are Copy Username & Copy password working? They don't work exactly the same that is unless you change the File > Options > Clipboard copy method > Paste once (secure)
I can't reproduce here with RDM but I have a script that might help us diagnose the issue on your side.
Could you please download and install this tool: https://www.linqpad.net/Download.aspx (LINQPad 5) Installer or xcopy (zip)
Then download the attached file, open it in LinqPad and hit F5
Press the Copy Username Password button and try the scenarios that you outline above (paste in Notepad, Chrome...). One at a time (close the window between tests), copy the result from LinqPad and please send us the results.
(edited : removed LinqPad script)
Stéfane Lavergne
Thanks Stefane
Requester: notepad++ (2035118)
Requester: chrome (3085308)
The first two requests are two pastes to give:
LINQPad - UserName
LINQPad - Password
as expected.
The two Chrome requests happen at the same time and paste just 'LINQPad - Password'.
I've turned off all extensions. Edge Dev shows the same behaviour. Pasting in the Omnibar works as expected, but pasting in the main Window generates two requests. Perculiar.
It's obviously a Chrome problem however. Have you tested in Version 78.0.3904.87 (Official Build) (64-bit)?
I have the exact same issue, can replicate.
Chrome 78 build adds this "Shared Clipboard" feature.
https://support.google.com/chrome/a/answer/7679408?hl=en
Shared clipboard between computers and Android devicesA limited number of users might see the option to share their clipboard content between their computers and Android devices. To share, they need to have Chrome installed, sign in on both devices with the same account, and enable Chrome Sync.
The text is end-to-end encrypted, and Google can’t see the contents.
This functionality will be released to all users in a future version of Chrome. In the full release, admins will be able to control it with an enterprise policy.
I'm having the same problem.
Nice spotted in the Chrome changelog, rolflobker - could sound like a possible cause.
I suggest you turn off the Clipboard sync in Chrome;
chrome://flags
Thank you all for the amazing investigative work.
I just got back from a week outside the office. I will try to test/debug the "copy username & password" to see if I can get it work nicely/properly with the Chrome "Shared Clipboard" feature enabled. We already set the two flags, specified by Windows, that identifies the clipboard data "private/sensitive" and that it shouldn't be stored/processed in any clipboard history local or cloud-based. So why is Chrome still doing it? One can only speculate.
My feeling is disabling the "Shared Clipboard" might be our only choice and may also be the safest. I'm not sure I want my usernames & passwords to be sent/shared across my devices via Chrome. There are more secure ways of sharing credentials other than giving them to Google via my copy/paste buffer in clear text.
Stéfane Lavergne
Does anyone know if there's a similar setting in the new Edge? I've searched and tried turning off anything remotely related to the clipboard with no change in behavior.
Whilst I agree it's best to be turned off for those that aren't using it, I've turned off shared clipboard and it hasn't fixed the original issue for me.
Hasn't fixed it for me as well.
I will also investigate a bit more when I have the time.
I think I found the solution. It should be included in the RDM build v2019.2.20.
If you want to test, I've attached the "improved" LinqPad test script that should work with Chrome.
Give it a try and let me know.
Stéfane Lavergne
Cool! But....:)
I have tested LinqPad with your improved test script with the new Edge - I get the same result - I only get the password.
Notepad works fine.
I don't have Chrome installed.
Some others have to do some testing of Chrome and also see if they get the same result in the new Edge, as I do.
Small update:
In the new Edge. If I try to do it in the address bar - it works (first username, then password). But trying in a web page (like this comment box I'm typing my answer in), only the password comes out.
The output of the clipboard test still shows both:
Requester: msedge (262656) - Value: LINQPad - UserName
Pushed LINQPad - UserName
Requester: msedge (262656) - Value: LINQPad - Password
Pushed LINQPad - Password
Please try this version.
Stéfane Lavergne
After further testing, Chrome should work but not Edge.
Edge looks and acts like the Windows Clipboard History service. It actually calls a thread of the Clipboard service to do the clipboard code for it instead of calling the clipboard directly.
Back to the drawing board...
Stéfane Lavergne
Please try this version with Edge
Stéfane Lavergne
Have tested it in New Edge Beta (Version 79.0.309.25 (Official build) beta (64-bit))... and it works!
When I get to work I'll test it in New Edge Dev.
Works fine in Chrome. It doesn't work in the Omnibox, but I can't imagine that being an issue for many.
Thanks Stefane
Just tested with New Edge Dev Version 80.0.328.4 (Official build) dev (64-bit) and Clipboard Test v4 seems to work everywhere (address/search bar and on web pages!
Cool - and thank you! :)
Wow it worked I'm honestly surprised.
Thank you all for the updates.
@roger01 - for Omnibox, send the output of the LinqPad script while you try to paste into Omnibox, I might be able to fix it.
Stéfane Lavergne
Hi Stefane
It's:
Requester: chrome (1314564 - 16308)
The first two lines appear on right click in the Omnibox, the second two on Paste.
Thanks
P.S. I don't actually need to paste usernames or passwords into the Omnibox, just happened to notice
