RDM hangs after double Azure SQL login popup's (auto went from offline > dialog to login)
Hey,
I have this issue from the beginning I am using this software, but now I finally took time to create a video of the behaviour.
When I open RDM and for some reason I want to stay offline I open it in offline mode.
After some while (dont know why or how) a login box will appear to login to the Azure SQL datasource (note the dialogue is displayed 2 times).
After closing the dialog (press cancel OR fillin password) the application hangs completely. Does not matter if you do/do not have internet connection / connection to the Azure SQL database.
Will attach a video of the issue.
I can easily reproduce, just need to wait a lilttle while after opening the application.
[ PS: this drives me crazy ;) ]
Indeed, this is very strange.
In File -> Data Sources, could you send me a screenshot of the Connection, Settings and Advanced tabs.
I would also need to know if the option Automatically go offline is enabled in File -> Options -> Application Start -> Start up online state.
