Connection to Wayk Den - add timeout
if you set up a Wayk Now connection with PFP permission and the remote user doesn't react to the permission window RDM should end the connection attempt in a (global configurable ?) time frame.
At the moment the window "Connecting to Wayk Den" are shown and RDM stucks and report not responding - it is only possible to end this with task manager and kill the RDM process.
PS: Because of an other issue with the PFP permissions we found for the moment a bypass solution: Following setting works with PFP permission:
in this constellation the config are saved, the password are ignored and the remote user receive the permission window
Thanks!
Min
All Comments (1)
Hello Min,
This issue must have slipped through, but we'll assign someone to look at it. :)
Closed
