Keep number of backups not working
I have started to use the Devolution RDM backup feature, but it appears that the "Keep number of backups" setting is not working.
I have set mine to 4, but the backups keep growing until the server runs out of space.
Please can you advise how I fix this?
I am running RDM v13.6.6.0 and using the Devolutions Console v5.1.1.0
All Comments (5)
Hi Adrian,
Are you doing Database backup, web backup or both?
Benoît Sansregret
Hi Benoit,
Both web and db.
Adrian
Hi Adrian,
I wasn't able to reproduce your issue but I'm still trying to figure out what could go wrong for you.
Could you send me a screen shot of the content of your Backup tab.
Also in your previous screen shot, I'am not able to see what the Notes and Sucess column are indicating
Benoît Sansregret
Hi Benoit,
I believe I have resolved the issue. This issue appeared to be a permissions issue on the folder used to backup to. I have amaned the ACL so local Users has Full Control on the backup folder and Devolutions is successfully backing-up and only retaining only 4 copies.
Thank you for your help.
That's great news
Have a nice day,
Benoît Sansregret
Closed
