Is there a way to fiew more than two embedded sessions on one screen or maybe a feature for the further releases?
It would be useful for the common Wide-Screen displays today
Draft is below with four embedded sessions, would be useful:
|_|_|
|_|_|
Like following documentation with two embedded sessions:
https://help.remotedesktopmanager.com/index.html?view_embeddedsessionssplitwindows.htm
I think what you're looking for is our Thumbnails feature.
This gives you a view of all your opened sessions;
https://help.remotedesktopmanager.com/commands_thumbnails.htm
Marc Beauséjour
I'm sorry, wrong described, mistake on my part
I thought this feature with a capable System-Administration for four RDP-Sessions simultaneously
Except this is possible with the thumbnail-view
Just to be sure, our Thumbnails feature is what you were looking for?
Marc Beauséjour
Hello
This would be the righ link:
With this feature you can manage/administer two remote desktop session simultaneously, so would it be possible (maybe in future releases or now) to administer four remote desktop sessions simultaneously?
It would be useful with bigger screens like widescreen monitors ( e.g. >= 27" or something else)
Current manageable sessions (restricted for two RDP-Sessions):
|_|_|
Question? (four sessions simultaneously):
|_|_|
|_|_|
Thank you in advance
Indeed it's a limitation from our third party. I will check what we can do.
in this video about Launcher:
https://blog.devolutions.net/2018/11/video/how-to-use-devolutions-launcher
at about 2:55 has much more powerful split screen then RDM - you can do horizontal and vertical splits simultaneously. RDM cannot do this.
How come launcher has this better then in theory more feature rich RDM :( and when are we getting it in RDM ?
And while making this a reality could there be some way to save sessions layout so that for example I can open 4 sessions with single open action in a 2x2 in a given position for each of there 4 particular sessions. Let's assume these 4 sessions are already defined in datasource.
I will do my best to improve RDM but Launcher does not use the same GUI technology behind the scene. RDM is build with Winforms and Launcher is build with WPF. It's nearly impossible to completely rewrite RDM with WPF.
RDM 2019.1 now supports the free layout docking. You can give it a try.
that's perfect :D
Thank you very much :D
I can split however I want now :)
I need to play with it more :)
I don't suppose some kind of saving layout (with sessions to open to fill it) would be possible so close to 2019.1 release but that would be great in the future :)
ps. And the black theme is really nice :)
Excellent news. I'm glad you like this. I'm not sure how (technically) I could save the layout, perhaps in a playlist.
Very nice!
Matt Broadfield
