[SOLVED] SSH - Do not lose context when connection is lost
Using RDM Free 4.0.1.0 and a SSH connection.
Currently, when a SSH connection is lost, the screen is being cleared. Would it be possible to let it as it is, in order to not lose the terminal text that was displayed.
Moreover, it would be nice if the terminal wouldn't be cleared as well when doing a reconnect.
In other words, exactly as Putty does it, as shown on the screenshot below:
Thank you for the request. We'll see what we can do to add this feature to the terminal.
We diverged a lot from the base PuTTY code as far as connection/disconnection/reconnection goes, which means it may not be easy to change. I can't give you an estimate on when the feature will be done because of this.
Alright, no problem. Thank you for your reply and for considering my request for now. :)
Hi guys,
I would love to see this feature in RDM. Any idea if we can count on it now?
This is still on our todo list. It's not easy to do but we're hoping to make progress on this. Denis will be taking a look soon.
I've seen that since the last release, the terminal is not cleared anymore after the connection is lost. This is great! Thank you for implementing this first step. :)
Now if the screen content could also be kept after a "Reconnect", that would be perfect. :cool:
Anyway, thanks!
Hi guys,
Any news for this?
This is still on our todo list but Denis is going to take a look this week.
Sorry about the long delay. We've made changes internally and it should now keep the previous context when reconnecting. We're planning to release an RDM Free version today, we'll try to have the change in that version, otherwise it will be available in the one after that.
As usual, the change will be available in the next RDM Enterprise version as well.
That's great news! Thanks for this improvement, it's very welcome. :)
Is there any chance the colors could be remembered as well?
I'll let Denis know about that, it should be possible.
Hi..
Please let me know if this has been resolved? If so, what setting should I change?
For me, when I reconnect, I lose the previous session. I would like to retain the previous session history in the window...
Thanks.
Are you using the SSH terminal entry or a different entry?
I tested on our latest version and it seems to work for me. Which version of RDM are you using?
version 2024.3.22.0 64-bit
Where do I find the terminal entry? When I open a node, it opens a Putty window.
Hi..
You have answered the query in my other thread "Do not lost previous connection history, when reconnecting the session"
Please close this thread.
