Have specific window settings configured for RDP connection and they are no longer being used.
Custom width and height are ignored, window position is ignored...
Do you use the smart sizing enabled or the mode set to scrollbar?
Here are the settings on the connection. RDP session is opening in a tiny window (800x600) in a completely wrong position on screen.
It should open a session to the remote computer at a resolution of 3440x1440 and position that window appropriately on the first monitor. Instead it's connecting to the remote system and changing the display resolution (the remote system needs to be displayed @ 3440x1440, not 800x600).
Just to be sure. You open it in external mode?
yes, external mode (new window outside RDM)
Could you try to export the entry to a .RDP file and verify the content of it?
Exported and the contents are fine. Using the RDP file externally from RDM works normally. Using the connection within RDM has worked once today, not sure what was different or why but it continues to open in an 800x600 window at the wrong position on screen.
This is really strange. In external mode we export the file to a .rdp file in the temp folder and open it. Perhaps you could verify the content right after you see that it does not work.
