Enable Smart Reconnect by default
is it possible to enable "Smart Reconnect" for all current and new connections by default so I do not have to enable it every time I connect to a server!
Thanks,
Manuel
All Comments (1)
zellaham
Disabled
1. For the existing connections you can make a batch edit by selecting all of them like so.
2. If you wish that this setting apply to all your newly created entry please go in File -> Templates -> Default settings -> Session.
Once there simply look for the RDP entry and do the desired modification it will then apply to every newly created entry.
P.S.
Also note that if all your RDP entries are set as scrollbar (the default settings) you can go in File -> option -> Types RDP and change the "Screen sizing mode " there.
Zacharia Ellaham
