RDM 8.1 freeze after system is off-line
Good Day
I have recently updated to version 8.1 of RDM and it's freezing then crashing on me on Windows 8.
It seems to only do so when the laptop goes off-line from sleep mode. If I have any open sessions (Usually only RDP) they don't reconnect and I end up having to force quit RDM. Let me know if there is any info I can get you.
Thanks.
All Comments (5)
What data source are you using (XML, SQL Server...)?
Please attach (or send via private message) your RDM logs? (Help -> View ApplicationLog)
Stéfane Lavergne
Using Dropbox as my data source.
I'll submit the log via PM, thanks.
I've seen a similar issue using other software (Google Chrome for example) where if I hit refresh prior to my network connection being re-established it will hang for some time. Once the network connection becomes available the app eventually responds.
Does it help (change anything) if you wait for the network connection to be re-established prior to using RDM? Does it still freeze? Does it freeze on its own without user interaction (background refresh)? Does it freeze every time you wake your PC?
Stéfane Lavergne
Just went to lunch and am experiencing the same thing. I do see the "Unable to retrieve data source informations from DropBox. I tried to click on "Retry" but it's still saying Not Responding. Waiting for the network connection does not change the behavior.
edited by gramsaran on 3/26/2013
It's not simple to reproduce but I will do more tests with sleep and DropBox. I'll come back to you asap.
André Sanscartier
Closed
