Passowrd Vault crediential View passowrd not visible
pesala
Disabled
Does anyone know why i could not see the " See Password " button (Eye Button) on my password vault?
pesala
Disabled
There should be a button like bellow,
Thank you for contacting our support services, in order to help you we would need the following information:
What version of RDM are you using?
Are you starting RDM with specific options ? (32-64 bits run as administrator or standar)
Normally if you are administrator of your database you should see the password. If you are connected with another user please be sure you check the box for Allow reveal password in the User Management.
David Grandolfo
pesala
Disabled
Hi David,
Thank you for the quick reply. The case was "Allow reveal Password" check is not set for the specific user.
Thank you. :)
Pesala SampathOperational Technical Engineer99XSchweigaardsgt. 14, 0185 Oslo
Postboks 9216 Grønland, 0134 OsloMobile: +94 70 3999925Skype: bopesala
pesala@99x.no
