create to 2 domains using my personnal credentials
Good morning,
I am using Remote Desktop Manager version 11.0.3.0, I have a question, I would like to know if it's possible to connect to two different domains using my personal credentials ?
it seeams that only one entry is possible (username/ password)
is it possible ?
much appreciated for your help
thanks
D.Doss
All Comments (4)
Unfortunately the My personal credentials only supports one entry. The real solution is to use the private vault instead. What data source type do you use?
We have tried with Password Volt Manager but we have to choose the credentials from a list
Can we save automatically our credentials ? We are using entreprise edition and we are using SQL Server Microsoft.
Thanks
Do you mean Private vault or Password Vault Manager? This is not the same. Here is the help about the private vault:
http://help.remotedesktopmanager.com/view_navigation_privatevault.htm
I have finally find a solution with Password Vault Manager
Thank you for your help
D.Doss
Ends in 9 days
