Hello, I use the new version of Remote Desktop Manager Free 2.6.4.0. In the old versions i could move the connection Tabs and so organize the order of all connections. With new version ist not more possible. Is this a configuration setting?
Could you try RDM Free Edition 2.7.1.0. You can download this version here http://remotedesktopmanager.com/Home/Download
Have you installed Windows 10 Anniversary update? If yes, it's seems to be the same issue reported in this topic
https://forum.devolutions.net/topic26461-unable-to-rearrange-tabs-drag.aspx
Right, this ist the same problem what i mean and exist only on Windows 10 Clients. Version 2.7.1.0 do not fix it.
With the help of Claudio from the following thread https://forum.devolutions.net/topic26461-unable-to-rearrange-tabs-drag.aspx, we may have found a workaround for the moment.
Could you try to change the RDP version to RDP 6.0 in File -> Options -> Types -> RDP -> RDP.
Let me know if the drag and drop is now working on your computer.
Thanks, that works, but it is not applicable for us, I can’t connect to all Server. We are waiting for a Fix.
We are working on it.
