Quick connect default username and settings
I cannot find where I set quick connect to always use a specified username and password, and also a specified resolution and settings. should be able to set from a template really.. i have so many servers that i cannot create a session for each.
All Comments (5)
You need to create a template and leave the user/password blank. The templates will appear in the quick connect drop down.
okay thanks.
i do have to say that the ctrl-shift-alt-Q "shortcut" for quick connect is quite hilarious. could you make it a bit shorter maybe?
We will make all the shortcut customizable in the next version (major)
by the way. the shortcut does not work everywhere. it's okay that it does not work when inside a rdp session, but it does not work when you are clicking outside a window. it just works when you have the navigation tab open
I have used a third party software to work on this, though I don't think if it is suggested.
Ends in 9 days
