Setup Gateway for RDP Connection
Hopefully you guys can assist me on an issue that I am encountering.
Is it possible to select which gateway the connection will take when attempting to RDP into a server.
Site 1: 192.168.10.x
Site 2: 192.168.20.x
The VPN is setup to connect on the 192.168.10.x range. However I would also like to connect to servers on the 192.168.20.x range.
How do I go about selecting the gateway for certain RDP connections? If I set it to 192.168.10.254 (the router) then hopefully it will connect fine.
I have had a look at the settings but can't seem to find what I'm after.
All Comments (1)
I don't think we have anything to support that. I will add a feature request for a prompt for Gateway.
