"prompt for password" and SSH connection
I use the combination of "prompt for password" in the credential repository entry and connect it to a SSH connection entry with putty.
from time to time I need to login to that SSH connection with a different user and I do not have the option to do so.
In the popup window I have the option to delete the user name but when I connect (if I delete it) it will still enter the username in the connection.
Either give the option in the right-click to bypass the credential entry during the connection or use the username I put in the pop-up.
Thanks
All Comments (4)
I will ask André to verify this and why your user is not used.
Thank you
I am not able to reproduce your problem.
Did you try with the beta version ?
André Sanscartier
This is not a problem this is a new feature I'm requesting...
I need the option to connect with bypass of the credentials.
It is possible in RDP connections, why not SSH ?
I have entered a feature request. It's not really complicated but we have finished the version 7.5. This should be in the next version.
