Addons problem
There's a problem with 2 addons:
SecureFX can't be updated
and
PowerTermPro1.0.0.0.zip can't be downloaded
Server Error in '/remotedesktopmanager' Application.The resource cannot be found.Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Requested URL: /remotedesktopmanager/download/AddOn/PowerTermPro1.0.0.0.zip
Version Information: Microsoft .NET Framework Version:2.0.50727.4216; ASP.NET Version:2.0.50727.4223
edited by kowal on 3/11/2012
All Comments (7)
I will verify this tomorrow when I'm back at the office but in the meantime, could you tell me what version of RDM do you use?
I'm using v7.0.2.0.
PowerTermPro should works now.
Could you confirm it please.
For SecureFX I am not able to reproduce your problem. I need more information.
What's happening when you try to install this Add-on ?
edited by ASanscartier on 3/12/2012
André Sanscartier
When i'm trying update from v1.4.0.0 to v1.4.0.1 everyting seems to be ok but after restart there is stll v1.4.0.0.
I was trying to install it manually but inside zip file dll version is also 1.4.0.0
oups...
Thanks for the information.
It will be fixed as soon as possible.
André Sanscartier
The SecureFx add-on has been fixed.
André Sanscartier
Yeah...now all is fine:)
